Showing content with the highest reputation on 09/05/2018 in Posts
  1. This Isle of Man 900 SS is the definitive Ducati restomod Full Size In the automobile world, if you need a millimeter-perfect restoration or subtle upgrades to the icon in your garage, you go to guys like Classic Motor Cars, Zweimüller or François Sicard. In the Ducati world, if you live in Europe and know your stuff, the name Harné Heuvelman is likely to be on your list. With the help of his son, Harné runs the workshop Back To Classics in the western Netherlands—and he can rebuild, redesign and remanufacture anything you need for a Borgo Panigale classic. Full Size BTC’s latest showpiece is this 1978 Ducati 900 Super Sport, an NCR-fettled racer that began life as a privateer entry in the Isle of Man TT. It was originally delivered to Steve Wynne of Sports Motorcycles, a key figure in Mike Hailwood’s TT success. Wynne sent the cylinder heads to NCR for a performance boost and conversion to twin-spark ignition. He also reinforced the frame around the headstock, fitted a new swingarm designed for longer suspension travel, and installed a set of (very early) Öhlins rear shocks. Full Size The bodywork was changed around the same time: there’s an aluminum long-range fuel tank and a proper racing seat. And there are plenty of other typical late 70s racing tweaks, including a stunning set of wide magnesium Campagnolo wheels. Harné’s client raced the bike throughout the 1980s and early 90s, and then parked it up in his shed for 20 years. “Then he decided to have the Ducati brought back to its former glory,” Harné tells us. Full Size On arrival at the BTC workshop in the rural village of Bergambacht, it was time for a check-up. “The frame needed straightening—probably because it was in a minor crash—but this was easily fixed. We did have to make (and weld) a lot of the lugs though.” The engine rebuild was a little trickier. “The bike had spent a lot of time on the racetrack, and many parts needed extra attention and in some cases replacement.” Full Size BTC rebuilt the crankshaft, and installed new Carrillo conrods. The Venolia pistons were matched to a new set of liners, bored and honed to the correct clearances. The NCR-tuned cylinder heads were rebuilt, and tuned and flowed still further. A new exhaust system was made up from steel tube, and ceramic-coated inside and out. Full Size The suspension is resolutely stock however, even though it would probably have been easier to machine up some new triples and bolt on later-model forks. “The rear Öhlins shocks were originally fitted in 1978,” says Harné. “We found out that Öhlins started up the same year, so these are very early units made by this company. We of course restored and rebuilt them completely.” Full Size The front suspension is the standard Marzocchi unit the bike raced with back in the day. This was also restored and rebuilt. The aluminum fuel tank is the original too, but with the dents removed. The seat is an original brought back to its former glory, but the fenders and front fairing are new items. Full Size BTC pride themselves on being thorough, right down to x-raying the wheels to find cracks. They even manufactured and fitted a brand new gearbox. “The gearbox is our own product,” says Harné. “It’s a standard street 3-dog version of the original 6-dog gearbox.” “We could have gone for a racing gearbox with different ratios, but decided not to—given the owner’s desire to be able to ride on the road as well.” Full Size Yes, this machine is road legal in the UK. It still has its original UK registration, so BTC made a few discreet changes while staying as close to a full racing bike as possible. There’s now a bolt-on side stand, a Motogadget rev counter with digital speedometer readout, a tiny horn, and lighting. Full Size Those parts—and the incredible rosso paint—are pretty much the only ones that weren’t made in the BTC workshop. Everything else was done in-house for this 900, including all the machining, the engine building and the restoration of aged individual parts. At forty years old, this Ducati TT icon is now in the prime of its life. Thank goodness there are still people like Harné Heuvelman and his son in this world. Back To Classics | Facebook | Instagram | Images by Ernst Klip. Full Size http://www.bikeexif.com/ducati-isle-of-man-tt
    3 points
  2. Tag zusammen, nachdem ich nun jahrelang nach nem vernünftigen Navihalter für die Multi gesucht habe und mich mit Fahrradhaltern und allem möglichen anderen Mist rumgeschlagen habe, hab ich jetzt einfach selbst einen konstruiert. War jetzt mit dem Halter auf 2 Touren über igs. 3 Wochen und die Lösung hat super funktioniert. Besteht eigentlich aus 2 Komponenten: 1. Stromversorgung von 12V Bordsteckdose auf USB mit Magnethalter 2. Gehäuse mit Sonnenblende für Iphone X Hab nen Haufen Prototypen gedruckt bis alles perfekt gepasst hat, jetzt bin ich wirklich zufrieden. Die Halterung selbst bleibt am Motorrad, die Stromversorgung hat man in 1 Sekunde abgenommen. Das Ganze basiert auf der Höhenverstellungshalterung die ich auch irgendwann mal mit der Montageplatte gekauft hatte, bot sich halt so an. Im Prinzip könnte man auch die Montageplatte nehmen und die Halterung mit 4 Schrauben befestigen. Ich hab mich jetzt für 2 Gelenke entschieden, da damit Winkel und Höhe flexibler einstellbar sind. Hab mir jetzt einmal die Arbeit gemacht und werde das für zukünftige Motorräder/Mobiltelefone einfach entsprechende anpassen, ist auf Basis der CAD Daten relativ easy möglich. Siehe Fotos in der Anlage (eins davon noch mit nem frühen Prototypen). Keins mit eingesetztem iPhone x, das brauchte ich zum fotografieren. :) Cheerio, Stefan
  3. Federbein ist leider noch in der Post ...
