Offiziell 1098R!!!
Seb
106mm Bohrung, wie krass!
Dazu eine Traktionskontrolle, die Latte wurde wieder ganz nach oben gesetzt von Ducati. Wirklich hammermässig.
RACING KIT
Every 1098 R is equipped with a racing kit designed exclusively for use on the track that has a pair of carbon “102dB” silencers to increase power and a dedicated ECU. The ECU enables the activation of the DTC (Ducati Traction Control) system with eight available profiles able to be selected through the instrument panel’s digital display.
CHASSIS
Frame Tubular steel Trellis frame in ALS 450
Wheelbase 1430mm / 56.3 in
Rake 24°30' / 24,5°
Front suspension Öhlins 43mm fully adjustable upside-down fork with TiN
Front wheel travel 120mm / 4.7in
Front brake 2 x 330mm semi-floating discs, radially mounted Brembo Monobloc calipers 4-piston, 2-pad.
Front wheel 5-spoke in forged light alloy 3.50 x 17
Front tyre 120/70 ZR17
Rear suspension Progressive linkage with fully adjustable Öhlins TTXR monoshock with top-out spring. Aluminium single-sided swingarm
Rear wheel travel 127mm / 5in
Rear brake 245mm disc, 2-piston caliper
Rear wheel 5-spoke forged light alloy 6.00 x 17
Rear tyre 190/55 ZR17
Fuel tank capacity 15.5L (of which 4L reserve) / 4.1 US gal (of which 1 US gal reserve)
Weight * Dry weight
Seat height 820mm / 32.2in
Instruments Digital MotoGP derived unit displaying: Speedometer, rev counter, clock, scheduled maintenance warning, warning light for low oil pressure, fuel level, oil temperature, fuel reserve, trip fuel, neutral, turn signals, average speed, average fuel consumption, remaining fuel metre, immobilizer. DDA system enabled.
Warranty 2 years unlimited mileage
Body colours (frame/wheels) Red / Racing Gold
Versions Single seat
* = The weight excludes battery, lubricants and, where applicable, cooling liquid.
ENGINE
Type L-Twin cylinder, 4 valve per cylinder Desmodromic, liquid cooled
Displacement 1198.4cc
Bore x Stroke 106x67.9mm
Compression Ratio 12.8:1
Power* 180hp - 132.4kw @ 9750rpm
Torque* 99.1lb-ft 134Nm @ 7750rpm
Fuel injection Marelli electronic fuel injection, elliptical throttle bodies.
Exhaust Lightweight 2-1-2 system with catalytic converter and 2 lambda probes. Twin stainless steel and titanium mufflers
Emissions Euro 3
TRANSMISSION
Gearbox 6 speed
Ratios 1st 37/15, 2nd 30/17, 3rd 28/20, 4th 26/22, 5th 24/23, 6th 22/25
Primary drive Straight cut gears, Ratio 1.84:1
Final drive Chain; Front sprocket 15; Rear sprocket 38
Clutch Dry multiplate with hydraulic control slipper clutch
* = Data calculated using an inertia dynamometer
close
Eine Verdichtung von 12,8:1 in nem Serienmopped is schon verdammt krank. Man man man. Nicht schlecht!
Warum ham die das Tankvolumen net vergrößert.... 15,5l das ist Bockmist, da haben die Entwickler Ihre Hausaufgaben nicht richtig gemacht. Der ist schon für die 1098 Basic bzw. S mit ihren 160PS viel zu klein, was soll denn das bitteschön bei 180PS werden? dann muss man wohl schon alle 120KM tanken bei Landstraßentempo?? Ich verstehs nicht....
Ich bin irgendwie auf keine Bauteile bei der Auflistung der R Specs gestossen , welche nun enorm teuer wären .
Geringere Stückzahl-ok.
Das macht die Kolben vielleicht 60 € teurer
Grössere Bohrungen in den Zylindern ~ 100 €
Die Kurbelwelle ( wenn überhaupt ) 100 €
TTXR Federbein ca. 100 €
Überarbeitete Electronic + Kabelbaum .... hm 300€ ?
Lackierung ~ 200€
Vergessener Kleinkram 2000 €
Also +2680 € für Ducati
Was soll die R nu kosten ?
Also ich denk mal Titanpleuel, Titanventile, größere Ein- und Auslässe, größere Airbox + Kanäle, eventuell ne andere Einspritzung (Durchmesser). Dazu noch nen KIT (gabs bei der Tricolore ja schon).
Carbonteile statt normalem Plastik, bisschen andere Elektronik wie die Traktionskontrolle.
Dass die nicht 20000 Euro mehr investieren und dann 20000 Euro mehr drauf schlagen ist dir doch auch klar.
Die wird niemals 10000 oder 20000 mehr an Ausstattung Wert sein.
Mensch Thorsten, da ist nen R auf der Verkleidung. Verstehst du, ein R! EIN R! :rolleyes: :smile_wacko:
was soll das Teil Kosten??? 30000€ oder noch mehr??? sorry,nur für nen "R" im Namenszug jenseits von gut und böse:mecker:
schick is sie,keine Frage.........aber ob das Ding auch nur annähernd die angegebene Leistung erreicht??? Diese ganzen "Werksangaben" von den Herstellern (allen) heutzutage sind doch nen Scherz........(fast) kein Hersteller erfüllt das was im Prospekt steht......naja egal,über mangelde Leistung braucht sich wohl niemand bei den aktuellen Bikes beschweren,"genug" Druck haben sie alle.
Nehmen würd ich die Duc trotzdem........obwohl ich ja nu nicht gerade nen Freund von Zweizylindern bin:p........weiß auch garnicht ob ich mit nen Zweizylinder klar kommen würde:denk1:
Ducati ist immer sehr nah an den Leistungsangaben. Die alten Modelle hatten immer etwas mehr als angegeben, die aktuellen passen laut diverser Prüfstände.
30000 Scheine haben die Rs immer gekostet. 998R, 999R und somit auch logisch die 1098R.
moin männers
bei der zeitschrift motorrad, lag die dauertest ducati 1098
genau 10ps unter der werksangabe von 162ps.
aber egal.
komme gerade von der eicma.
1098r absolut sexy.
und ist sogar leichter als die desmosedici.
gruss
chr
Naja, die 1098 hat ja auch nur 113KW/154PS laut Fahrzeugschein.
Die Ducatiangaben sind nach einer abweichenden Richtlinie/Norm gemessen.
Ducati selber schreibt dazu
--> "Ducati hat sich mit dem Modelljahr 2005 zu einer Änderung bezüglich der Angabe der Motorleistung und des Motordrehmoments entschieden, wodurch es zu einer Abweichung bezüglich der Nutzleistungs- und Drehmomentangabe zwischen Prospekt- und Werbematerialien einerseits und den Fahrzeugpapieren andererseits kommt.
Grund hierfür ist, dass die Angabe in den Fahrzeugpapieren zwingend auf einer nach EU-Richtlinie 95/1 ermittelten Nutzleistung beruht, korrigiert auf die laut Richtlinie vorgegebenen Normbedingungen. Hierbei wird die Nutzleistung auf einem Motorenprüfstand unmittelbar an der Kurbelwelle ermittelt.
Alle Angaben in unserem Prospekt- und Werbematerial beziehen sich auf die auf einem Rollenprüfstand ermittelte Nutzleistung an der Kupplung, korrigiert auf die laut ECE vorgegebenen Normbedingungen."
