Titan-Teile für Duc 900-1198
Jens39
Moin Männers,
 der Bob de Boer von LBM Engineering in Holland legt ne Serie von Titan-Teilen für die älteren Ducs auf. Kupplungsdruckstange, Scheiben usw. Siehe hier:
Hello we have started engineering quite a lot of parts for the Ducati bike from the 900 to the 1198
Here already some engineering pictures!
What parts are we all going to make out of titanium:
* Clutch pressure shaft
* Spacers with oring for behind the front sprocket and behind the clutch
* The heavy steel ring of the coasting gear (behind the alternator)
* The sliding shafts for the gear shift forks and rocker arms
* Additional lighting of the gears
* The shaft through the lower block that drives the camshaft belts
* The metal plates of the clutch
* The camshaft belt tensioners
* Switch mechanism where you drive the switch roller.
* Our own titanium mufflers with optional db killers
We are going to make these into production!
Also for sale. So if you are interested in these beautiful exclusive parts titanium please send with a message
The rest of the engineering pictures and st/prices will be announced soon already in progress. And almost start whit it to de cnc
Kind regards LBM Engineering.
Sobald da was genaues zu verfügbaren Teilen und Preisen rauskommt werde ich das hier reinstellen. Da is auf alle Fälle was für mich dabei.
