FS: "new" Leovince TITANIUM EVO II asymmetric version muffler with homologation code for Ducati 749/999 all years/models
David
Hi guys , for sale LEOVINCE EVO II full Titanium silencer for Ducati 749/999/s/r "asymmetrical version" it can be fitted on all 2003-2006 years models , you only need to use stock pipes to fit it or link pipe for eliminate the kat.
An very rare and unique occasion to buy this piece of art because that is homologated for street use.. Only few version of these muffler were made with homologation code on it for that this is very rare and expensive to get or find one nowdays.
As you can check from picture , that is the -big mouth version- like wsbk Leovince muffler .. Silencer was bought brand new long time ago and used for very low kilometer on the road before parts off the whole bike for sell it.
That like "brand new conditions" as you can see .. no scratches/no crack/no damage welding/repair or other bad things..simple perfect, carbon cover is totally new. Coming with all these parts you can see from pics -leovince db killer alredy fitted on that ,
Top support for fit on oem rear monoposto tail + all steel bracket support parts fitted under muffler for fit stock rear headlight and license plate mounting, nothing missing for this plug&play kit !
After you bought that , i will send you an link and all info you needed for required to Leovince the homologation sheet with your ducati model type + your ducati frame number + homologation code you can find on the silencer,
then guys from Leovince will send you this card by email , print and bring that with you for don't get any trouble on the road.
Price: 2.000 Euro shipping not included
some more info about this titanium EVO II muffler:
EVOII canister design
11.45lbs weight savings
About the Product
LeoVince SBK Factory Slip-On Systems
SBK Factory exhaust systems are the top street systems available from LeoVince. They are constructed with a TIG-welded stainless steel AISI 304 mid-pipe (or full header) leading to an all-titanium or carbon canister with a carbon fiber end cap and mounting strap providing significant weight savings.
They are designed to increase horsepower and run at peak efficiency with stock jetting or fuel injection settings.
All titanium internal silencer construction
All titanium properly welded in an oxygen-free environment for maximum strength
Available with titanium or real carbon fiber canister sleeve
Significant weight savings over stock
Slip-ons boost horsepower an average of 5% across RPM range
Mid-pipes made of TIG-welded 304 stainless steel
Real carbon fiber canister straps and end cap
Aluminum and 304 stainless steel mounting hardware kit included
Produces deeper tuned tone at a reasonable sound level
EVOII silencer insert removable for more aggressive tone
CAD/CAM designed for precise fit
Machine-specific tuned to work with stock fuel settings
