Drehmoment Reifenwechsel
phantomass
Front brake calliper screw 10x1.5 43* GREASE B
Front brake bleed valve M 6x1 12
Front/rear brake hose fitting M 10x1 20
Front brake master cylinder / handlebar screw M 6x1 9 1 (UP)-2-1 Sequence
Screw securing front brake line guide to bottom
yoke
Front and Rear Wheels
Rear wheel nut M 30x1.5 180* GREASE B
Front wheel spindle nut M 25x1.25 63* GREASE B (apply to
thread under nut head
and in wheel spindle)
Fixings securing cush drive pins to sprocket ...... 55 * LOCK 5 (LH only)
Chain ring nuts M 10x1.25 46 * GREASE B
Front/rear brake disc screw M 8x1.25 25 * LOCK 2
Nach dem Anbau der Bremszangen die Pumpe betätigen bis du Bremsdruck hast. Soll Leute geben die fahren los ohne das zu machen...
