MM Competition Systems (lies: Nemesis ECU Hersteller), haben für die Ducati Desmosedici RR ein eletronisches Race Kit bereit gestellt.
Wie folgt:
Competition Systems Ltd have developed a ‘bolt on’ set of race electronics specifically for the Desmosedici RR. Each kit comes complete with all of the hardware, wiring, adaptors and software to make this possible, without any need to modify the bike or alter the wiring.
* LCD race display with lap timing
* Professional race proven traction control with handle bar mounted push buttons to change the TC-level
* Launch control
* Anti-wheelie
* Pit lane speed limiter
* Internal data logger with professional software
* Closed loop ‘wide band’ lambda control for each engine bank.
* Plug ‘n’ play installation
* Full access software to allow for further engine or bike modification
* Quick shifter with retard and cut
* Pre-loaded with ‘ready to race’ maps
The Magneti Marelli SRT engine control unit with integral data logger is at the heart of this system coupled with the Marelli MDU-020 dashboard display.
Each system we produce is not only fully mapped, it has a well developed and race proven traction, launch and wheelie control system as standard.
Electronics of this level are notoriously complex both to install and operate, but we have made this easy with a set of ‘plug in’ wiring adaptors, hardware mounting kit and pre-defined (but adjustable) software settings.
No parts of the original bike are damaged or modified* during the installation process to ensure that all can be returned to original factory specification at a later date.
(*Except lambda bosses which are welded into the exhaust pipes.)
Broschüre Download
Offizielle Webseite:
Competition Systems
Direkt zum Produkt:
Plug 'n' Play ECU for Desmosedici RR
