Ergebnis 1 bis 7 von 7
Thema: 1198 SP für 2011
    Gast Gast
    Standard 1198 SP für 2011
    Nothing special, is it?
    petzi ist offline Erfahrener Benutzer
    14.11.2006
    282
    doch ! silver stripes !
    Geändert von petzi (05.10.2010 um 19:20 Uhr)
    Avatar von lolek
    28.05.2008
    531
    Hi,
    die Silver Stripes sind aus Alu, wie der Rest des Tanks
    Und sonst gibts jetzt serienmäßig einen Schaltautomat, eine Anti-Hopping-Kupplung, ein TTX Federbein,
    Stunning 'SP' performance
    The 168kg (370.3lb) (dry weight) 1198 SP creates a dream package by taking everything that the 1198
    model has, including DTC, DDA and the new DQS systems, and adding top-of-the-range Öhlins suspension,
    lightweight chassis components, a lightweight factory team-style aluminium fuel tank and slipper clutch.
    The high performance, fully adjustable 43mm Öhlins forks, which sport low friction titanium nitride-treated
    fork sliders, respond effortlessly to every imperfection in the tarmac. Beyond their advanced engineering
    solutions, one of the most important characteristics of Öhlins forks is their ability to communicate the
    condition and quality of the tyre-to-road contact patch, a feature that puts every rider in superior control. The
    suspension set-up at the rear is complemented with a fully adjustable Öhlins TTX rear shock equipped with
    a ride enhancing top-out spring and mounted to a single-sided swingarm for outstanding drive and traction.
    The front-to-rear Öhlins package is completed with a control-enhancing adjustable steering damper.
    On any sport or race bike, the most effective area to reduce weight is its 'unsprung weight'. These are
    components like tyres, brakes and wheels. Lighter wheels have a lower 'moment of inertia' that is
    beneficial with every direction change and application of the brakes. The 1198 SP addresses this important
    area by mounting 7-spoke Marchesini forged and machined wheels. Both front and rear are super
    lightweight and their benefit is immediately apparent. The weight saving is further enhanced with the
    application of a carbon fibre front fender.
    The 1198 SP weighs in at 1kg (2.2lb) less than the 2010 1198 S thanks to the beautifully made lightweight
    fuel tank, which also boosts the bike's fuel capacity by 2.5 litres (0.66 US gal) to 18 litres (4.75 US gal). The
    tank is formed in 2mm thick aluminium, brush finished and then painted and clear-coated to create a racing
    stripe of natural aluminium that accentuates the factory race tank feel.
    The 1198 is supplied with the Ducati Data Analysis (DDA), Ducati Traction Control (DTC) and Ducati Quick
    Shift (DQS) systems as standard equipment. The DDA package enables the retrieval and analysis of data
    collected from a previous track session or road trip and DTC monitors front and rear wheel speeds to detect
    rear wheel-spin under acceleration and electronically reduces engine power to restore traction. DQS allows
    the throttle to remain open when changing-up through the gearbox, helping to save vital seconds in the
    pursuit of faster lap-times.
    The 2011 1198 SP is available in two colour schemes. The traditional Ducati red is now supported by a new
    diamond black and completed with red Trellis frames and black wheels with signature red pin-striping.
    Geändert von lolek (05.10.2010 um 21:14 Uhr)
    Duc-Schmidti ist gerade online Erfahrener Benutzer
    ... also der übliche Restteile-Abverkauf vor dem Modellwechsel.
    Haut mich auch nicht um das Ding.
    Avatar von lolek
    28.05.2008
    531
    Hi,
    och, ich find die ganz schnuckelig :)
    14.11.2006
    282
    Zitat Zitat von lolek Beitrag anzeigen
    Hi,
    als wenn ich's nich geahnt hätte...
